Scooter not picking up properly ........... HELP!
alanscottj
Scooterdude wrote: Sun Sep 30, 2018 8:10 pm When you charge your stator dont ditch the old one. Instead buy and fit a Ducati/Piaggio lt coil and pick up and keep as a spare.
Thanks for the tip, I'll be sure to do that. I really hope it sorts the problem as it's driving me around the bend!
Now, I am not sure which flywheel I have (light/mid etc) - can I just buy any stator and swap it? If so which is the best?
garry inglis
A.c. or dc have you a battery bgm or scootronics around £85
garry inglis
This is scootronics a.c. and I just fit external pickup Image
alanscottj
garry inglis wrote: Sun Sep 30, 2018 8:37 pm A.c. or dc have you a battery bgm or scootronics around £85
No battery - AC - think I'll message Anthony and see if he has any ready to go, failing that i'll go BGM :D cheers bud
garry inglis
He's in Korea next week so a week on Monday before you can order bgm are good
alanscottj
garry inglis wrote: Sun Sep 30, 2018 8:49 pm He's in Korea next week so a week on Monday before you can order bgm are good
Yes, he just messaged me! Cheers bud :D
Scooterdude
Yes the Anthony Tambs ones are very good, the BGM ones not so good. Mine went within 6 months from new and ive heard similar stories.
If you can get a SIL one from Scooter Restorations in Nottingham that may be a better choice.
Daggs
If I've followed this ? You've effectively tried two CDi's and two pick-ups.
In my experience LT coils break down when hot. This means when the scoot has been running for some time and/or distance.
I'm not certain it's an electrical problem.
I'm wondering about the carb. and or settings. Or perhaps a mechanical problem.
Without seeing the scoot for myself it's difficult to diagnose.....
HxPaul
I have an AC system and I use one of these - https://www.facebook.com/photo.php?fbid ... ater&ifg=1 - It takes its power from the lighting coils,so with your external pick up and this CDI it cuts out everything apart from the lighting coils from your stator plate.
johnny650
Main scooter: lambretta 64 li 150 Special
I'm inclined to agree with Daggs that it is a carb issue .
Clearly it is only effecting the throttle pick up off of idle by your description .
The idle is presumably stable so rather than the Pilot jet or air jet it could be the slide...... the slide is responsible for pick up off idle to approx 1/8th of throttle range.
Try this simple experiment. next time you go to pull away apply a little choke and see if that improves initial pick up. if it does pick up better then it would suggest you need to change your slide to a richer one .
from MB Scooter site 'Dellorto slides 26 - 30mm PHBH 30 35 40 45 50 55 Alloy
    Users browsing this forum: Google [Bot] and 10 guests
