My 1980 Vespa P200e turn signals...
railfancwb
I got the turn signals working properly on my 1980 Vespa P200e, including the indicator light by the speedometer. Even with the indicator light I still tend to forget to turn the signal light off.
I am thinking about putting a buzzer into the circuit to help me remember.
A picture showing the location of the flasher behind the battery position.
Portion of wiring schematic showing indicator light (5) and flasher (15).
So my questions...
1) put the buzzer in the dashed red wire between the flasher and the indicator light?
2) is there a better place to put the buzzer than near the flasher behind the spare and battery?
3) was there a variation of the P series which came with a buzzer and if so where was tha buzzer placed?
Thanks!
Lambretta67
Main scooter: Lambretta L.I. 200 special
I think the first T5's had a buzzer. People disconnected them as they were annoying
gaz_powell
T5 mk 1 featured a buzzer, mounted inside the glove box top right of the door.
Have a look on SIP website they will probably have one which will give you an idea.
Pretty simple to break into the indicator wiring.
Gaz
railfancwb
Thanks!
