Can I fit Vespa 125/150 pipes onto a 200 and if so, what do I need to do??
Raff72
There seem to be a bunch of cheap pipes available from Indonesia. I've used some of their smallframe zorsts in the past and they worked quite well. I am now thinking that I could try and fit a 125/150 pipe onto one of my 200s??
It seems to be a case of using a downpipe fit for purpose??
Any help and or advice would be much appreciated
Norrie Bodge
On certain pipes that have a sprung downpipe yes
Done it for a mate who bought a revolver pipe
HotPearlSnatch
Main scooter: Lambretta series 2
Er, no, not unless you graft [cut and weld] a 200 down pipe onto the [indonesian?] box.
125/150 vespa exhausts have a different down pipe exit angle [from the pot] to the 200s. I know because i have cut and shut the two together quite successfully in the past [sito + pipes].
Don't think there is an issue with Lambretta exhausts other than the barrels exhaust stud spacings being different between small and large block motors, same exit angle though.
HotPearlSnatch wrote: Tue Sep 04, 2018 3:13 pm Er, no, not unless you graft [cut and weld] a 200 down pipe onto the [indonesian?] box.
Lambretta exhaust studs same on small / large block it's the carb manifold studs tha are different.
HotPearlSnatch
Blimey!!!
So my 48mm fresco down pipe will fit my 125 frame breather?
I admit its been a long time since i tried....maybe 30+ years :geek:
