Stopping panels falling off
Warrick
Main scooter: Lambretta Avanti
My panels have a bad habit of falling off, what is the best way to stop this
Panel locks or is there any other tricks?
Ta Warrick
bazza3004
Clip on type ?. Put a bit of fuel pipe over the clips where they hit rear of frame and it will put extra tension on them
Warrick
Yes they are clip on, not original panels. They were newish clips with rubber on to make them tighter. I’m sure after a few months they get lose again
There must be a more full proof way
Are the panels straight and fit nicely all along the loop?
Get a metal dowel shaped and welded across the bottom of the panels, and up at the ends. It'll make them a lot stronger and stiffer.
I'll find a pic of how mine were done when I get home if you want.
LI150
Main scooter: Series 2 LI150
Weld a plate we’re the clip sits on the panel so it has further to travel to unclip. A plate about 15mm will do
What sort of Clips are you using some Cheap reproductios loose their tension very quickly
Tractorman
Toddy wrote: Tue Jul 17, 2018 6:10 am What sort of Clips are you using some Cheap reproductios loose their tension very quickly
Very true some of the clips available are rubbish.
Like this..
HxPaul
