Shock Absorber eye to stud sizes issue
loadedscooterist
Main scooter: lambretta li150 special
Hi All,
I have been doing further bits to the scooter - this time a replacement for the shock absorber. However, I have encountered a strange issue. The eye of the shock top and bottom wont fit onto the studs/lugs as the eye is too small to fit onto the lug. When I measured the two the difference is approx 1-1.5mm out (i.e. The eye hole is 18.5mm and the stud looks approx 20mm (so it will never fit even with grease!).
I spoke to the supplier of the shock and he had a similar issue not long ago where a shock wouldn't fit the lug on a particular scooter but fitted on others fine. Has anyone else encountered something like this before and what did you do about it?
I have thought about getting a step drill bit and making it slightly larger so it fits. Good idea or bad?
holty
Main scooter: lambretta gp
i have seen the inside sleeve rusted onto the frame shocker mount, that would have stopped the shocker fitting, does it fit on the engine ?
loadedscooterist
No that's the odd thing. The actual lugs are in good shape, no rush. Just a bit big....
boxofbits
Cheers may try a diffrent piston, reed valve would work i think but would need a piston with holes in it i think
mick1
Main scooter: Li Avanti 225
boxofbits wrote: Sun Jul 01, 2018 4:16 pm Cheers may try a diffrent piston, reed valve would work i think but would need a piston with holes in it i think
My thinking as well :shock: if it's the rear shocker try a different piston.......
Obviously posted on the wrong thread but amusing all the same.....
Timbo
ringwoodrob
I've had it the other way with fitting a new Indian Escort shock there was too much slack in bush sleeve to lugs resulting in massive vibes through whole scoot felt like engine mounts had gone!!!!!!!!!!
    Users browsing this forum: Google [Bot] and 19 guests
