Rear hub stud sizes
tavspeed
Had some sip tubeless rims to fit for a mate
Wound out the existing studs. No problems but couldn’t get the sip studs to wind in measured them with verniers sip measure 10mm on the left hand part the original ones 8.7mm
has he got a oddball hub or are the sip studs wrong
tavspeed
Rear hub havent tried front hub yet
garry inglis
I have two sets of sip wheels and the studs just went in as normal if one of your mates has a spair wheel he should have spare studs try them for size
Minority
Main scooter: Li230 S3
Standard thread size 10 x 1 (left hand), sounds like you have an odd size hub. :(
dennis
Main scooter: 1 gp 1 special
sounds like it's a ramp rear hub,they are smaller stud threads.
Burnside
Main scooter: Lambretta TV200
dennis wrote: Thu Jun 28, 2018 5:01 pm sounds like it's a ramp rear hub,they are smaller stud threads.
If it is a Ramp hub I'd ditch it straight away
