If excessive travel is replacing both shift cables the prudent thing to do?
In fact the grip position in fourth gear may be a bit further around than shown. Closer to the center line of the switch housing.
Are you saying replace the housing as well as the inner cable?rosscla wrote:Is there slack movement back and forth that doesn't lead to a gear change? If not, it may just be where your gears are. If yes, then you might want to start with adjusting the cables, if the adjusters are at max then release the nipples, screw the adjusters in, pull the cables tight and tighten the nipples.
If they look frayed / worn then replace. If replacing get nylon lined / friction free ones.
