wont start
2439sean
just doing about 40mph and it just died like id run out of petrol full tank though done all the usual checks cleaned carb checked its sparking changed spark plug made sure the petrol cap isnt blocked but still wont start checked all the electrics
its a
rapido250
34mm dellorto
jl3
electronic igntion re wired indian by andy francies
done 2500 trouble free miles and now it just wont start any ideas
cheers
carlos fandango
is the plug getting wet ? if it is then its more likley to be electrical if its not then is a fuel problem.
This is the basic check when it wont start. then its a process of elimination.
If you have a spark is it a strong one ?
First off change the plug, because faulty ones can still spark!
Check stator has not come loose and moved again it will still spark (just not in the right place)
The other thing it could be if every thing else is ok is execessively worn rings. to check this instead of stripping down pour a little oil down the plug hole is should then start ;) for a minute any way !
nigesx200
could possibly be a faulty pick up box on the stator plate :?:
    Users browsing this forum: Google [Bot] and 23 guests
