Black sooty oil from exhaust
Strummer10
Guys any idea what a black sooty oily smoke from my clubman might be caused by ? Running a TS 1 at 3% oil ?
Worn oil seal
Strummer10
Would that not empty out the gearbox though over
say 200miles ?
Strummer10
Is it prudent to stick a cloth over the exhaust see if it cut out, or would that cause a good seal to blow ?
Strummer10
Thanks for response........Sorry could not edit the above posts, but I normally associate a blown drive side seal with clouds of white smoke and no gearbox oil, or very little.
Grumpy225
The only time I've seen black smoke is when the mag side seal gave up and was washing the grease out of the bearing.
Strummer10
Grumpy225 wrote: Fri May 18, 2018 8:03 pm The only time I've seen black smoke is when the mag side seal gave up and was washing the grease out of the bearing.
Must confess it does clear after I get going. Before I do a full strip down, what tests can I do folks ?
    Users browsing this forum: Google [Bot] and 29 guests
