Looking for engine case engineering drawings
fluff34567
Hi all,
extreme long shot but I'm trying to find the engineering drawings that shows the dimensions and details of the main engine case... Any idea if these even exist?
Sent from my BND-L21 using Tapatalk
eden
Yes they do
fluff34567
eden wrote:Yes they do
Well that's a start, so next step is where can I get the details for the hub bearing area?
Believe Scootopia has them but if that doesn't work out who or where else?
I'm guessing the guys who are currently producing casings - Casa, Uni, GT etc will all have their drawings but it's whether they'll share them - depends what you have in mind.
Maybe you should have asked if there were any in the public domain?
Perhaps if you approached one of them with a proposal they might be willing to help if it wasn't against their commercial interests?
mick1
Main scooter: Li Avanti 225
Rich Taylor is now producing casings and he might be worth a call
fluff34567
Cheers for all the replies, will contact those listed .
ZERO commercial use, I'm trying to save a case that's had significant damage around the hub bearing bore and to assist the remachine I'm wondering if the drawing shows datums or other measurements to help me find the centre.
Rich_T
Main scooter: Li Special
To find the centre line of the hub bearing you first need the the centre line for the case. The case centre line is between the rear side case dowel and the forward-most exhaust stud. Clocking off the centre of the gearbox lay shaft bearing, the rear axle centre line is 69.31mm aft. Hope that helps
fluff34567
Hi Rich,
Just sent you a message on Facebook with some details.
    Users browsing this forum: Semrush [Bot] and 10 guests
