Yes the piston moves freely and retracts fully. The cylinder is flush now that I've skimmed some material off the pads. I fitted those washers temporarily when I was trying to work out what the problem was.coaster wrote:Mine cylinder sits flush but I did have an issue with the piston sticking now I think of it but I noticed it before I fitted it. Had a bit of trouble getting the piston out so that I could give it a rub with some wet & dry. Is you piston going all the way in?
Sent from my SM-A520F using Tapatalk
