Gearbox shimming - feeler gauges
db67
hi, hope this doesn't sound like a daft question but where abouts should the feeler gauges be placed on the endplate when measuring the endfloat on the large gear shim ? thanks for any info ;)
ForemanBob
Main scooter: GP RT230
The hardened bearing cup that is inserted into the end plate has an L shaped side profile....
you are measuring the gap between the shim and the bottom of the L...
garry inglis
db67 wrote:hi, hope this doesn't sound like a daft question but where abouts should the feeler gauges be placed on the endplate when measuring the endfloat on the large gear shim ? thanks for any info ;)
Here's a picture put the feelers gauge in between the large washer on top off 1st gear and the endplate Image
garry inglis
Look for 0.30 to0.07
db67
Thanks for the replies guys & the info, plus the brilliant diagram ;) that has definitely made it clearer :)
    Users browsing this forum: Ahrefs [Bot], Google [Bot] and 1 guest
