Semi hydraulic inboard brake
hendy
Sun Apr 15, 2018 5:27 pm
As there was a complaint about lack of pictures and discussion, here are some pictures of my new brake.ImageImageImageImageImage
Sent from my SM-A520F using Tapatalk
Sun Apr 15, 2018 7:04 pm
Which hub is that?
Drum or disc links?
I like your thinking on the cable fixing I was thinking of doing something similar with a pull type master cylinder.
hendy
Sun Apr 15, 2018 7:22 pm
rosscla wrote:Which hub is that?
Drum or disc links?
Disc links from mb. I know you can get cheaper but I'm fed up of buying sub standard gear.
The hub is part of a complete inboard disc from beedspeed. Quite a lot of fettling. I opened up the holes etc. Also, some minor parts were missing like the screw for the fixed pad. I replaced the original pads with sintered but had to skim 2 or 3mm from each one so that they'd fit.
Those rope grips work better than I'd expected.
Muppet
Sun Apr 15, 2018 7:35 pm
dont like the angle of ya cable coming out of adjuster screw; it’ll rub the inner cable cable am thinkin it cud fray were it rubs
im not a complete idiot
s me of the piec s are mis i g
hendy
Sun Apr 15, 2018 7:44 pm
Muppet wrote:dont like the angle of ya cable coming out of adjuster screw; it’ll rub the inner cable cable am thinkin it cud fray were it rubs
Good point. The adjuster screw is slotted so I left it in a position where The slot is out of contact with the inner. I'm not sure how to resolve your point though. I'll take a look tomorrow afternoon when the lager wears off. Remember this is hidden away, so if it fails it'll be a rather unpleasant surprise.
All suggestions welcome.
Sun Apr 15, 2018 9:27 pm
I can see what Muppet means but that looks like its in a 'relaxed' position, I would imagine that the tension pulls it straighter when being operated or are those thimble clamps rubbing on the cylinder and holding the cable at that 'cocked' angle? Generous dollop of grease will help.
Sun Apr 15, 2018 9:37 pm
I also have one of these brakes and did the same mods as you except that the Scootopia sintered pads needed nothing more than rubbing the paint off the edges to make sure they didn't stick. Mine uses an external master cylinder but it works very well, the MOT guy got it to lock up on his rollers!!
hendy
Sun Apr 15, 2018 9:38 pm
First of the 2 pictures shows the cable under maximum tension. Second with no tension at all. In both pictures it's rubbing against the starboard side of the adjuster.
If I slot the mounting holes of the mounting bracket it will align so that it makes no (or very little) contact with the adjuster.
hendy
Sun Apr 15, 2018 9:51 pm
coaster wrote:I also have one of these brakes and did the same mods as you except that the Scootopia sintered pads needed nothing more than rubbing the paint off the edges to make sure they didn't stick. Mine uses an external master cylinder but it works very well, the MOT guy got it to lock up on his rollers!!
Reall? I couldn't even get the master cylinder to sit flush!
In the second picture you can see the difference between the pads.
Bad batch?ImageImage
Sun Apr 15, 2018 10:27 pm
Mine cylinder sits flush but I did have an issue with the piston sticking now I think of it but I noticed it before I fitted it. Had a bit of trouble getting the piston out so that I could give it a rub with some wet & dry. Is you piston going all the way in?
    Users browsing this forum: Google [Bot] and 0 guests
