PHBH carb leak
Blenks
Main scooter: Lambretta S3 Li150
Got to the exciting point today of starting the scooter after a complete strip and rebuild. Started no problem and I think all the electrics are working as they should. I let it run for 5 mins or so but noticed there is a fuel leak on the carb. It is a Dellorto PHBH 30. Seems to be leaking between the float bowl and main body. I don’t believe it was leaking prior to strip but can’t be 100%. So the questions are, is it likely to be the seal? is it an easy task to change the seal on the float bowl? Any setting after doing this. I literally disconnected the hose connecting to the manifold and removed the cables. It has stood for a while though.
garry inglis
Blenks wrote:Got to the exciting point today of starting the scooter after a complete strip and rebuild. Started no problem and I think all the electrics are working as they should. I let it run for 5 mins or so but noticed there is a fuel leak on the carb. It is a Dellorto PHBH 30. Seems to be leaking between the float bowl and main body. I don’t believe it was leaking prior to strip but can’t be 100%. So the questions are, is it likely to be the seal? is it an easy task to change the seal on the float bowl? Any setting after doing this. I literally disconnected the hose connecting to the manifold and removed the cables. It has stood for a while though.
Just tighten it a bit and they are easy to replace carb gasket kit about £6
Adam_Winstone
Have you fitted a clear float bowl.... they always seem to leak!
Blenks
No I’ve changed anything on the carb at all. It has the standard black plastic float bowl. I’ll order a gasket kit and have a bash at changing them.
HxPaul
Is the jet holder tightened enough,this doubles as the bolt that fastens the float bowl on.
Mrnice71
Float height not right , constantly filling bowl , float needs adjusting so it shuts the float needle valve jet off sooner
Blenks
Replaced the float bowl seal and O ring on the bolt and no more leak. Thanks all for the helpful suggestions
Blenks
I was wrong. The leak is still there but not as bad. I have tightened the jet holder bolt as much as I dare. I have never done anything with carbs before so not familiar with issues or assembly. When I removed the bowl I could not see the needle so not sure of the condition. Is there anyway of testing or diagnosing the problem. I’m not too confident of replacing floats etc. I really do not want to start stripping the scooter down again either. Don’t want to run it until this is sorted.
HxPaul
Is the choke jet seated properly
Blenks
Sorry Paul I have no idea what that is. I wouldn’t know where to start looking for it. Perhaps I should let someone with some knowledge have a look at it for me.
