bristolmod
- registered user
- Main scooter: Lambretta TV175 S3- what else!
- Location: Bali-Hai bar, Locarno Ballroom Bristol, 1967!- mines a Brown Split!!
- Contact:
I think I may have one out in the garage- how can I be sure?
Chris
Chris
Scootering since 1968.
- sean brady scooters
- Dealer
- Contact:
i,m pretty sure that the original spec of the gt200 barrell could be re produced...........using some modern repro barrels...............without the expense of remaking the original..........
it would only involve some porting work......................
and of course the use of much better pistons................
- ringwoodrob
- registered user
- Contact:
first gear can be a problem when pulling away from the lights(uphill) but more use of the right hand gets her away!
she will even plod at 30 in top on the windy roads of the New Forest takes most small inclines without changing down,i think the del25ml helps with this,runs rich low down make it weak and she loses her low down torque!
this kits somewhere around 6years old now shes due for another change of rings maybe the end of February I'll check wot the port size is then!
- ringwoodrob
- registered user
- Contact:
156 D wrote:Interesting read "ringwoodrob".....i for one would be very interested in the port sizes when you do a ring change.....would you also please measure the depth of the inlet at it`s shallowest eg: inlet flange face to bore measurement....also what type of head?....
Thanks Keith
Your website`s great....
up to 2008 she was always run on 4*leaded,i had the intention of putting a original sx200 head on(which i have)but never did,with the bump up in price to 12£ a gallon of leaded fuel last year i've now gone to unleaded!
would the lower comp head give more torque low down?,she does not have the top speed of a"ring breaker"best would be 65mph on a speedo revamped by Jem Booth!
- Information
Who is online
Users browsing this forum: Ahrefs [Bot], Google [Bot], Semrush [Bot] and 65 guests
