Kickstart engagement.
holty
Main scooter: lambretta gp
i would try making the slot for the peg longer and see if that helps, it could just be a badly made piston and a bad shaft, combined making it worse, or maybe just buy a better piston and new spring, and try them all together, ive heard of this problem before and known a new shaft fix it, lets face it the kickstart design is not very efficient on a lambretta and has to be very good to work perfectly, check the peg is not hitting the engine casing as well, they can be to long, i had some problems with my kickstart on my rotax and a new casa shaft and piston fitted perfectly, but they are not cheap.
psychedelicropcircle
Plan A the slot
Plan B phone JB & pass on the bill!
Thanks for the advice folks will keep yous posted👍
Slot ground out, no difference!
Mozambique!
holty
a new kickstart shaft and piston would be my choice, good quality and new piston spring
holty wrote: ↑Thu Mar 15, 2018 9:47 pm a new kickstart shaft and piston would be my choice, good quality and new piston spring
Going back to MB I believe
    Users browsing this forum: Google Adsense [Bot] and 6 guests
