Tried all the usual suspects (cables, levers etc) but still getting drag. Cable is now very, too tight imo. Seems if I go the other way i get too much slip (it's on a casa 225) esp when engine warm. Would I be correct in thinking next steps would be to look internally, looking at using different thickness clutch shims. i did make sure the height matched the front sprocket when building the engine. Or perhaps should i upgrade plates and springs? Or grind metal plates...how have people set up theirs? Cheers
Sent from my ONE A2003 using Tapatalk
Af rayspeed cassette clutch set up
- Toddy
- registered user
- Main scooter: Lambretta Series 1
- Contact:
yes Check the shimming, did you also check that the inner set up (Plates ) fitted in the Sprocket ok and moved freely ?
mick1
- registered user
- Main scooter: Li Avanti 225
- Contact:
The thread that the clutch basket fastens onto can sometimes be a thread or two too high. This prevents the clutch getting full travel. It's recommended to have the clutch nut flush and sometimes the threaded shaft has to be filed or ground down.............happened on my mates
- garry inglis
- registered user
- Main scooter: ts1 230 and rb200
- Contact:
Ray actually sits and files every clutch before they are sold so the plates should be right if you got it from rayspeed if you didn't then they mabye need a file or as Mick says the thread can need a feral on some
Finny
- registered user
- Main scooter: Lambretta series2
- Contact:
Thanks for quick replies. Got it from Andy Francis so ill start filling. In recall the basket was a little tight but still moved. Maybe it's fine margins.... especially when bolted down.
Finny
- registered user
- Contact:
Thanksmick1 wrote:It's the height of the christmas tree i'm talking about. The thread at the top of the tree can protrude too far through the clutch nut, restricting clutch travel.
- Scoot
- registered user
- Main scooter: Lambretta Jet200
- Contact:
I had the same issue with an BGM clutch. Used a shortened clutch arm, MB sell them now. And filed an old lever so that out opened further. Together they gave me more travel and got rid of the drag.
Sent from my iPhone using Tapatalk Pro
