AF 5 speed gear box
Timbo
Not my review so hopefully the guy won’t mind, interesting read I thought.....
Gone 5. The AF Gearbox with the AF 6 plate clutch. Review.... well it’s transformed my scooter. Set up is Ts1 Taffspeed pipe 34mm Tmx carb.
19 - 46 sprockets. (Heavy scooter and am no light weight) 😂
Right pros makes Scooter so so nice to ride, 1st 2nd and 3rd scooter pull really well 4 gear 65mph still pulling at 6200 RPM the scooter is so smooth. Drop it into 5th and the scooter sits there very little vibration and still pulling right up to to 8000 rpm (you can work the speed out for yourselves😀). tongkin along. It’s put another 10mph on the scooter Easy. Great touring set up. Better fuel consumption.
Con’s now am being picky..... you have to get used to the gear range ie you don’t need to drop to 3rd pulling out of corners. The other is the gear control. Very little movement on the gear select on the bars.
BEST thing you can invest in without a doubt.
10/10
Thanks to Jon Gilbert Warren Shaw and Chalky.
hendy
Do these work with Li clutch?
alanscottj
hendy wrote: Sun Feb 25, 2018 7:18 pm Do these work with Li clutch?
Yes they will, and GP.
