Fork tube roller bearing
chippy
Any advantage in using the taffspeed tapered roller bearing in frame fork tube. Ta
HxPaul
If the original bearings are greased and tightened correctly, I dont see any advantage of the tapered roller bearings.
Muppet
will let you know when I fit mine; expect smoother fork link movement over the pressed bushes
C’est la vie
I think the OP meant the ones that are designed to replace the upper steering race not the link pivots.
hendy
I can't see how it would make any difference really. A conical bearing resists side loads in addition to thrust loads so unless it's installed with the narrow part of the cone uppermost it will be pretty much the same. Conical bearings make sense at the bottom of the tube though.
Muppet
rosscla wrote: Fri Feb 02, 2018 12:25 am I think the OP meant the ones that are designed to replace the upper steering race not the link pivots.
again will let you know when I fit the new tapered upper race and tracks to me own :)
C’est la vie
Scooterdude
hendy wrote: Fri Feb 02, 2018 7:39 am I can't see how it would make any difference really. A conical bearing resists side loads in addition to thrust loads so unless it's installed with the narrow part of the cone uppermost it will be pretty much the same. Conical bearings make sense at the bottom of the tube though.
Would completely agree with this.
