Kickstart bump fitting hints
loadedscooterist
Main scooter: lambretta li150 special
Hi All, Just a really quick and hopefully easy one to answer. My Serveta was missing the kick start bump rubber so I went and bought another to fit into the engine casing. However, its really tight to get into the hole (oooh errrr) so has anyone any tips to make this simple task easier in fitting it!
Apologies up front for the daft question!
Cheers!!
Daggs
Use a junior hacksaw to cut a very shallow groove along the length of the bump rubber, this allows air to get out and not compress. Some stops have this groove, others don't.
Use a smear of grease too.
garry inglis
Put in hot water for 5mins and itll go in
Vaseline
Oh, you said 'bump'...
Tractorman
Main scooter: Lambretta li150 special
It is possible that it's the wrong size anyway, not that you are ever sold substandard parts!!!
loadedscooterist
Hi all, thanks for the handy hints. I don't think its the wrong size its just as tight as the proverbial nats chuff! I will give your suggestions a try!!! Cheers!!!
HxPaul
A lot of people,me included,remove the bump stop rubber so the kickstart sits higher.Makes it easier to start while on the stand.
Burnside
Main scooter: Lambretta TV200
Whenever fitting any rubber parts I always put them in boiling water for 5 mins 1st, makes them nice and pliable
dave81
Main scooter: SIL GP 150
Be careful when fittting the stop. I could hear the teeth rubbing on the start gear teeth when the engine was running.. Had to remove the stop a few times and cut a slither off until it went in the casing far enough to let the kickstart go higher and stop the noise.
    Users browsing this forum: Baidu [Spider], Semrush [Bot] and 6 guests
