its only to cover over the flywheel, ive got an external pick up and trigger sticks out a long way, mainly as ive removed a lot from the flywheel, it will stop the pickup from getting damaged.
lambretta 290 rotax
Well... how did it go?! It sounds good!
- registered user
- Main scooter: lambretta gp
- Contact:
it seems to go pretty well, i do need to run it in before i dare to give it some welly, carb will need setting up, im sure it will be weak, so i will get it on a dyno to be sure, but first impressions are good.
- garry inglis
- registered user
- Main scooter: ts1 230 and rb200
- Contact:
Sounds nice that exhaust turned out well as well as the rest well done holty
- registered user
- Contact:
cheers garry, yes exhaust does sound good, time will tell how much power its got, but its very torquey , its got a gt200 gearbox and 17 front sprocket, but it pulls very easy through the gears.garry inglis wrote: ↑Thu Dec 07, 2017 11:44 am Sounds nice that exhaust turned out well as well as the rest well done holty
Well done that man sounds mint looking forward to seeing a full test /Dyno run
- registered user
- Main scooter: 1975 Vespa Rally 200 Femsa
- Contact:
That sounds lovely... great work!
- registered user
- Contact:
after ryans piston melting problems with his rotax, it has been suggested that these big engines need a bigger stinger in the end of the exhaust so i have been altering my exhaust, removing the 26mm pipe and fitting a 30mm replacement
heres a few pics
Untitled by stephen holt, on Flickr
heres a few pics
- garry inglis
- registered user
- Contact:
How much louder has it gone has it got a deep rumble
