I have an imported Vespa (‘72 GTr 125) that I bought around five years ago and the area that frame number is stamped (below l/h fixed side panel) has suffered some surface corrosion over the years & as a result of the pitting from the surface rust, the frame number is basically illegible.
I was aware of this when I acquired the scooter, it’s all legit & nothing dodgy - it was originally a German Military Signal bike & it came with some documentation from back when they released it, showing the original frame & engine numbers...
I want to get the scooter UK registered & to do so I need a dating cert - but without being able to provide a legible photo or pencil rubbing of the physical frame number I can’t do this...
So my question is - what’s are my options with regard to re-instating the frame number onto the frame within the parameters of legality?
Can I simply Re-stamp the original numbers (as stated on the German Army release doc) in the original location on the frame ? Or - is it better practice to stamp the number on a small plate & then rivet to frame over original location ?? ....and would the latter suffice for obtaining a dating cert for DVLA purposes?
Frame Number... or ‘lack of’
cartmel808
- Main scooter: 1975 Vespa Rally 200 Femsa
Hi Graham
Stamp the number on a piece of metal like you've said. This is the method I've used with my Rally 200.
Good luck with it.
Good luck with it.
cartmel808
Cheers for the reply Paddy.
How’s the Rally resto coming on?
