Mag flange
cgt75b
Main scooter: lambretta
Hi peeps
One of the threads has gone on the mag flange where the stator fixes too it.
What's the easiest fix?
Cheers for any help.
bristolmod
a bodge is to drill and tap just close to the knackered thread.
Scootering since 1968.
Steve t
Helicoil kit cheap enuff from eBay and easy to do in ally
garry inglis
Or tap out to m7 and put a 7mm dome head bolt in
Scooterdude
I'd use a timecert, failing that a helicoil.
Grumpy225
cgt75b wrote: ↑Fri Nov 17, 2017 6:10 pm Hi peeps
Other than the 2 M6 threaded holes for removing the mag flange there aren't any other threaded holes where the stator sits.
Regardless, any stripped thread can be fixed with a helicoil or timesert. The trick is making sure it goes in straight.
cgt75b
Cheers for the advice fella's I'm gonna go down the helicoil route I think.
Thanks.
cgt75b
Are the eBay kits any good? Because I've had some proper shite off their.
Grumpy225
I use these. Maybe Amazon or Ebay sells them.
https://www.threadkits.com/perma-coil/m ... /1221-306/
Easy to install and haven't had one fail yet.
HxPaul
cgt75b wrote: ↑Fri Nov 17, 2017 9:39 pm Are the eBay kits any good? Because I've had some proper shite off their.
Yes.I've used them a couple of times when the thread on the chaincase is stripped (the one that holds the tailpipe bracket of the exhaust)
    Users browsing this forum: Google [Bot] and 9 guests
