Can someone tell me the easiest way to fit a new plastic carb reducer to a Dellorto 2/22 carb please
Ive tried everything I can think of and cant get it to go in
Dellorto carb reducer fitting
- HxPaul
- Main scooter: lambretta Li 150
It should just push in,with a little persuation,when you have the old one out.What I did the last time I fit one,I put the reduction sleeve on the manifold and knocked the carb on with a mallet.
Adam_Winstone
- Main scooter: Lambretta GP
I tried some from one source and... not a chance of fitting it!!!!
I ended up then buying one from Scootopia, as made for their 22mm Dellorto copy and ... BINGO! Correct size and fit.
Scooterdude
- Main scooter: Lambretta LI 125 S3
You could try heating it in boiling water, that'll make it go all floppy and should be easy to fit..
Adam_Winstone
If it is anything like the first one I bought, no way you'll get it fitted to a genuine Dellorto. Without doubt, the insert would have need to be reduced in size before it would fit.
Adam
Adam
Adam_Winstone
Well done for getting it sorted.
