175 kit, what cylinder head?
diesel
This arrived last week and I'm struggling to see why its a seconds. The plug thread could be tidier but it holds a plug well and as far as I can tell makes a seal. The finish on the combustion chamber is rough toward the gasket face and could do with a rub but the gasket face itself is fine apart from all that I've seen worse and it will do without fettling. I'll give it some tidying and run it but I don't anticipate any difficulty. The postage to Ireland cost nearly as much as the head but it was still cheap as chips. If it suffers a catastrophic failure I will let you know (if I can)
