just fitted sip speedo pulse cable
garry inglis
just fit the new pulse speedo sender and thought i would share my setup fitted to my ac special you fit it as you would the normal speedo end and connect the the other end to the actual speedo connection it says set to pulse 6 instead of 0.77 fitted the rest of speedo temp /fuel/button all worked as i set it up on the bench with a 12v battery also a sip wheel fitted with 3/50/10 s1 tyre worked out at 1304 tyre circumfrence whent for a spin and it was running 10/12mph faster than my sat nav changed to pulse 7 got to 4mph changed to pulse8 and spot on with sat nav it works great ands alot easier than trying to setup the senser and its great having a speedo that i no is correct speed
Timbo
Is the speedo sender new?
garry inglis
Image all working I must admit that all the complications everyone else went through setting these up and putting it on this forum made it easy for me Image
garry inglis
Yes timbo well pretty new
Timbo
What extra parts are needed to set up the sensor, going on a standard front disc brake.
garry inglis
None just the cable screw in as normal at the bottom and connects to Speedo on appropriate connection and set to pulse 6 setting mine up with sat nav I ended on pulse8 to get the ratio speed correct
Timbo
Gary i’m a bit confused, so the pulse cable doesn’t use the magnet on the wheel?
garry inglis
Timbo wrote:Gary i’m a bit confused, so the pulse cable doesn’t use the magnet on the wheel?
No torbay lambretta and lambretta upgrades sell them £29 they work great it cuts out all the magnet brackets easy to set-up
garry inglis
HereImage
garry inglis
HereImage
When your setting the Speedo measuring unit setting it asks for internal or external put in internal and a number comes up put in no6 and try it out go for a run mine was 15mph out changed to no7 was around 7mph out changed to no8 and spot on with gps
    Users browsing this forum: Google [Bot], Semrush [Bot] and 14 guests
