Spanish series2
wayne cudine
Main scooter: Lambretta Lis150 Eibar series2
How do all, I've gone n got misen an Eibar series2 li 150 and was wondering if it's possible to put dampers on the front forks considering the fixing bracket for the mudguard which seems to be in the way. Hope you can advise.
Ta very much
Cue
Ass far as I know the dampers go behind the fixing brackets
Sent from my SM-G903F using Tapatalk
wrecklessrobbie
Main scooter: li150
Yes you can. Very easily.
Af rayspeed welded mine on.
There is a thread on here discussing this somewhere with photos.
I fitted my dampers before fitting the mudguard. It gets quite cramped in there.
wrecklessrobbie
Main scooter: li150
wayne cudine
Ta very much, looks like a trip to af when I get it back to mine for a strip down.
hendy
Just had mine done. Normal welded on damper mounts but with nuts welded on outside. I can post photos tomorrow if you like.
Just in case anyone needs any damper lugs welding on ImageImage
wayne cudine
hendy wrote: ↑Fri Oct 06, 2017 11:43 pm Just had mine done. Normal welded on damper mounts but with nuts welded on outside. I can post photos tomorrow if you like.
That would be good if you could. Ta
Cue
hendy
https://flic.kr/p/ZeDEMJ
Sorry but I can't work out how to embed images so a link will have to suffice.
wayne cudine
Cheers for that Rich much appreciated
Cue👍
    Users browsing this forum: Ahrefs [Bot] and 4 guests
