Fitted an af road clutch yesterday and when it was all back together I can't compress it at all, the cable is moving freely and it's not trapped behind the shock. I have no idea what's causing it but before I split it open again I'd like an idea of what's causing it
Af road clutch won't disengage
Bensmith225
- registered user
- Main scooter: Lambretta gp monza 225
- Contact:
- garry inglis
- registered user
- Main scooter: ts1 230 and rb200
- Contact:
If it's a gp casing did you fit the brassplunger the right way round and did you try it for smooth operating and sometimes you need to file it down a bit and did you fit the top cap weather it's gp or li witch has a nipple on
Bensmith225
- registered user
- Contact:
You've got me thinking about the plunger now as it did drop out while I was fitting the casing I guess it is possible I put it back in the wrong way round , the plates slid into the crown wheel nicely and the top cap is in it
dapper
- registered user
- Main scooter: The Biriani Bullet
- Contact:
I had a similar problem and found that the christmas tree was too tall, stopping the centre button from moving inwards at all. Changed Xmas tree and all fine.
Bensmith225
- registered user
- Contact:
That could be the case, I put a new box in when I fitted the clutch I suppose I could grind the tree down to give me more clearance
Bensmith225
- registered user
- Contact:
Took it to bits, the plunger was fine and the plates move freely so I'm guessing it's the nut and Christmas tree
alanscottj
- registered user
- Main scooter: Lambretta GP SS250 Casa
- Contact:
I had the same problem - took about 2mm off the Christmas tree and worked spot on
Bensmith225
- registered user
- Contact:
It was the nut all along! Just shaved it and it moves in and out nicely with the clutch compressor
- corrado
- Dealer
- Contact:
Ben at Rayspeed said that should cure it, when Chiselspeed stronger springs were used.Bensmith225 wrote: ↑Mon Sep 18, 2017 10:27 am That could be the case, I put a new box in when I fitted the clutch I suppose I could grind the tree down to give me more clearance
Bensmith225
- registered user
- Contact:
It's all sorted out now. Operates properly and once it beds in it should stop being so snatch
