lambretta Bearing sizes and up to date prices
Piatti
Hi,
Just compllied this list of Bearings for Series 3, plus an up to date prices from Simply Bearings
I need to order all of these and am comparing prices at the moment
1. Flywheel/Magneto side - ref: NU205 ECP – size 25x52x15
2. Drive side – ref: 6305 C3 2RS – size 25x62x17
3. Final drive (rear hub) – specialist lambretta bearing ?
4. Gear box end plate - ref: 6004
5. End plate layshaft (needle) size 20x24x10
6. Small end needle roller (fits in Con Rod) - size 16x20x20
7. Gear cluster (needle), slots in casing - size 16x22x12
8. Rear sprocket needle roller (2 Required) - size 24x28x10
Simply Bearings prices for the above -excluding Final drive(rear hub)
1 x 63052RSRC3 Sealed Ball Bearing 25x62x17mm £6.33
1 x SKF NU205ECP Single Row Cylindrical Roller Bearing 25x52x15mm £26.49
1 x 6004 Open Type Deep Groove Ball Bearing 20x42x12mm £3.00
1 x K20x24x10 Needle Roller Cage Assembly 20x24x10mm £3.78
1 x K16x20x20 Needle Roller Cage Assembly 16x20x20mm £6.55
1 x K16x22x12 Needle Roller Cage Assembly 16x22x12mm £5.48
2 x K24x28x10 Needle Roller Cage Assembly 24x28x10mm £13.20
Items Sub Total: £64.83
Royal Mail 1st Class Post UK ONLY (1st Class Post): £1.50
VAT: £11.61
Order Total: £77.94
Regards
Piatti
Is it for an Li /SX/ TV crank? NU205 bearing.
GP will need NU2205 bearing.
Geocamper
Main scooter: Tv175 S2- Li 150 S2 Eibar
Is there a similar list for a series 2 Li150 bearing engine rebuild?
List for series 2 would be the same surely?
nellyboyo
Yes I am being serious and don`t call me Shirley .....ha ha ....waited years to say that sorry
Warkton Tornado No.1
Main scooter: Lambretta SX200
Nothing wrong with NTN/SNR for the cylindrical roller bearings & here's a web page of a UK seller that might even discount to Club Members:
https://buybearings.co.uk/series/nu-series/page:2
(Having said that, I don't recall ever paying more than about £15 locally for FAG)
