Rear light units
Not normal dan
Main scooter: Scomadi/Li150
Now my series 3 65 eibar has a Carello rear light unit fitted, it's knackered and I want to run the BGM led rear light so is it possible to swap it over for the CEV light unit??
Cheers in advance
garry inglis
yes you can any s3 fits
Not normal dan
garry inglis wrote:yes you can any s3 fits
Cheers Garry
Grumpy225
Not normal dan wrote: Mon Sep 04, 2017 4:16 pm Now my series 3 65 eibar has a Carello rear light unit fitted, it's knackered and I want to run the BGM led rear light so is it possible to swap it over for the CEV light unit??
Cheers in advance
just buy a LED lamp and call it done. Far easier ( more reliable and cheaper) to change the bulb than to change the whole tail light housing.
Google search "LED 1157". They are a DIRECT replacement for your tail lamp.
wrecklessrobbie
Main scooter: li150
Will they led 1157 work on ac ?
Shipleystevep
I managed to fit the bgm (type) led into mine ok. Bit of fettling is all
Grumpy225
wrecklessrobbie wrote: Thu Sep 07, 2017 10:08 pm Will they led 1157 work on ac ?
Yes (technically they are off 1/2 the time but at 1500rpm and faster it's too fast to notice). I run them in all of my bikes (BGM AC stators), have for years with no problems. Any auto parts shop should sell them. If you can't find them locally try Amazon.
The LED board type tail light is an expensive solution to a cheap problem.
wrecklessrobbie
Main scooter: li150
Thank you Grumpy
I shall get one 😊
Robbie
