What Sprockets??
Bilko
Main scooter: LI150
I'm looking advice what sprockets to use for the RB250.
It'll be used for mainly local running, two up. With occasional blasts on the motorway
Probably a PM Pipe
I also don't know what gearbox to use. I've an LI150 & a Indian GP200
Is that enough info?
Bilko's Oily Blog
simon k
i run 19 47 on a gp 200 box with a franspeed race. was initially using 20 front sprocket but struggled to find the right length chain.
16 x 47 with the Li 150 will give 4.99, GP200 with 18 x 47 will be 5.2, I wouldn't go taller than 4.99 if you're going 2 up.
Bilko
Main scooter: LI150
This is embarrassing posting this on the forum, but what way does taller work? Does it mean a higher drive ratio figure?
I've seen in Sticky's book how to calculate. I can't get my head round it though. (too thick)
Now as I'm going to be riding most the time with a heavy load I take it I need a higher drive ratio figure. Is that right?
Bilko's Oily Blog
simon k
rider weight is a huge factor, i'm around 65kg. but with the kit putting out around 20lb's of torque it pulls two up no problems.
goldeneye
Bilko, lower the number, higher the ratio. ;) 8-)
red
Bilko wrote:This is embarrassing posting this on the forum, but what way does taller work? Does it mean a higher drive ratio figure?
Too thick! You said it :)
Heavy load-do you mean you're a fat b*****d or is it all the crap you carry on it for rallies!! ;) :D
Bilko
Main scooter: LI150
Thank you Red, you say all the nicest things. :oops:
Bilko's Oily Blog
