yes it was a good day, i might just have this up and running for next year, yes see you at bridgarry inglis wrote: ↑Sun Aug 06, 2017 6:24 am Yes great to meet you as well holty had a great day out and fun ride back home acting like I stole it lol see you at Bridlington![]()
lambretta 290 rotax
holty
- Main scooter: lambretta gp
holty
done a bit more work on the exhaust pipe , more pics to follow later
IMG_1118 by stephen holt, on Flickr
IMG_1119 by stephen holt, on Flickr
IMG_1119 by stephen holt, on Flickr- garry inglis
- Main scooter: ts1 230 and rb200
looks good holty how are you working out the tuned length too suit the engine tune or are you just making it fit and see what adjustments may be needed
- garry inglis
I learnt from Martin at chiselspeeds when he trys his ads 3/5/6 he has them on the wall as a length of pipe with the combustion chamber but can fit each one by the two exhaust studs and has them sticking out from the side on the dyno looks weard but you can see the length difference in each pipe which we no is so important you'll sort it holty you have engineered harder projects than this
holty
just about done, might add one mounting later
Untitled by stephen holt, on Flickr
Untitled by stephen holt, on Flickr-
holty
clutch spider altered to fit the basket, its bolted and welded, built the welds up the fingers a bit to add support
holty
clutch basket extended, i will be reducing the size a bit later when ive worked out how many plates i can squeeze in
Untitled by stephen holt, on Flickr- garry inglis
thats some neat welding on the basket why not try for an 8 plate packer plate for casing extend kickstart shaft go on holty be the first go on go on
holty
ive got 2 5mm packers and the extended center bush and kickstart extension , i intend to get 2 sixplate conversions and see how many plates i can get ingarry inglis wrote: ↑Wed Sep 06, 2017 7:05 pm thats some neat welding on the basket why not try for an 8 plate packer plate for casing extend kickstart shaft go on holty be the first go on go on
