Oil Seal Names
GFlint
Main scooter: Vespa PX200
People seem to call the seals by different names, are the following correct combinations and are there any others?
Tks
Gary
Crankshaft Engine/clutch/drive side seal
Crankshaft ignition/Flywheel side seal
Internal & External Rear Hub/Drive shaft seal
If you don't tinker, you won't learn anything, but you won't break anything either :)
hungdog
GFlint wrote: ↑Thu Aug 03, 2017 9:24 pm People seem to call the seals by different names, are the following correct combinations and are there any others?
Tks
Gary
Crankshaft Engine/clutch/drive side seal - Derek
Crankshaft ignition/Flywheel side seal - Curley
Internal & External Rear Hub/Drive shaft seal - Mustava :lol: :D
GFlint
I have excessive smoke, which must mean i have a leaky Derek! :)
