5 speed box fitting tips
alanscottj
Think I ended up 20-47.
Works out final ration 4.57.
[/quote]
I think I ended up with 46x18 but I can't remember! Should of written it down :roll:
Fux
Main scooter: li150 S2
Fellas,
I`m fitting my 2nd cyclone 5.
Did you use the little shim that fits between layshaft and bearing in the endplate?
also, damn the splines on the gear cluster have a realiy tight tolerance! I have to use a 3 pronged puller to get my LTH cluch off.
Fux
Job done.
Piece of cake with the granturismo endplate and octipus layshaft.
Ended up with 1mm gear shim, no shim under the layshaft and no shim over the gear cluster.
Fingers crossed. haha
dirtyhandslopez
psychedelicropcircle wrote: Mon Jul 31, 2017 1:30 pm ^thats the one I've just fitted was a little surprised the ribbed side didn't have oil slots in them, perhaps an expert might know as to why?
Not expert by any means, but I would think that if a groove is machined, the gear would be very thin where you machine the groove, making it weak..
That's not going anywhere...
    Users browsing this forum: Baidu [Spider], Google [Bot] and 20 guests
