As above really, just been going through my stripped bits and noticed my side panels aren't matching.
One is what I can only describe as a standard Li whereas the other looked more like a silver special panel.
https://flic.kr/p/XhuuUs
Which one is correct?
What side panels should be fitted to my Eibar Li150 series 3
Not normal dan
- registered user
- Main scooter: Scomadi/Li150
- Contact:
- garry inglis
- registered user
- Main scooter: ts1 230 and rb200
- Contact:
Standard li I have one
- garry inglis
- registered user
- Contact:
Mine
Not normal dan
- registered user
- Contact:
- garry inglis
- registered user
- Contact:
Mind you if it's between 66 and 74 they had special panells
Not normal dan
- registered user
- Contact:
Cheers mate, mines apparently a 1965 quite early apparently for a Spanishgarry inglis wrote:Mind you if it's between 66 and 74 they had special panells
Mine might have the Li panels then, cheers mate for info
- garry inglis
- registered user
- Contact:
Here is some Spanish info from lambretta archive
Not normal dan
- registered user
- Contact:
Thanks mategarry inglis wrote:Here is some Spanish info from lambretta archive
Not normal dan
- registered user
- Contact:
My number begins with 059***
It did have the eibar badge on the front though ????
- garry inglis
- registered user
- Contact:
Some had eibar and some serveta mine's a 68 and it had the original serveta badge on
