Casa 200 ss kit....
H,POOL GADGE
Main scooter: vespa polini220/gts 300
Hi, asking on behalf of a friend,,,,he's just had had it dynod @ bhp 21.91 and torque 14.84 is this the best you'll get???or is there a lot more to be gained??? if you know or running this kit could you please pass on your 'setup' and 'dyno readings'.....thanx lads
garry inglis
i built one last year and about the same out the box 22hp/15fbt mine seized up at 400 miles fu##ed the barrel and piston due to being sold the wrong carb rubber and sufferd air leek
garry inglis
I've just been in workshop and got the dyno and carb settingsImage
garry inglis
Carb settings vhsh 30mm Image
garry inglis
Sorry had 30mm pbh on at the time
H,POOL GADGE
hi gary, many many thanks....he's not a kick in the arse off ye dyno readings....he's on a 34mm carb! WHAT GEARBOX WAS IT??? He,s on a 125 li box!!!
garry inglis
Li150 x46x16 4.9 pull like crazy
garry inglis
Just to add the super tourer was no good with this kit it splutterd till 5ooorpm then would kick in but still no good put ads5 on and pulled from 3000rpm right through I actually put the ads5 on my ts230 goes like fuc#
