lambretta 290 rotax
holty
Main scooter: lambretta gp
hi garry , i thought you might recognize it, it off an rb 20 barrel so im using the rb reeds.
holty
heres a pic of the barrel packer plate and a couple of pics of the carb fitted
ImageIMG_1069 by stephen holt, on Flickr
ImageIMG_1071 by stephen holt, on Flickr
ImageIMG_1070 by stephen holt, on Flickr
garry inglis
you have plenty clearance there and i remember now when you first started this that you were using the rb reed thats a good idea on the end plate as well have you had a look at casa lambrettas new 18 spline layshaft /8 stud hub /bearing and other bits only about £280 should really strengthen the back end up
holty
a couple more pics, ive added a bump stop
ImageIMG_1094 by stephen holt, on Flickr
ImageIMG_1095 by stephen holt, on Flickr
garry inglis
I wondered about the bump stop and suspension travel very clever👍
garry inglis
A lot of welding are you not worried about porosity and air leeks remember my ts230 casing that leaked like a sieve
holty
garry inglis wrote: ↑Fri Aug 04, 2017 7:35 pm A lot of welding are you not worried about porosity and air leeks remember my ts230 casing that leaked like a sieve
good point, the guy who did the welding said it wasnt easy, i wont find out for sure till i do a leakdown test, nice to meet you today gary, its always good to put a face to a name, your ts1 sounded spot on and was worth the hard work you had building it
RManson
A leakdown test is necessary for not only the inlet, but also to ensure there is no coolant leaking into the crankcase, etc.
garry inglis
Yes great to meet you as well holty had a great day out and fun ride back home acting like I stole it lol see you at Bridlington 😎
holty
RManson wrote: ↑Sat Aug 05, 2017 10:07 pm A leakdown test is necessary for not only the inlet, but also to ensure there is no coolant leaking into the crankcase, etc.
i wont have that problem as my water inlet feed is into the barrel via the hole under the exhaust port, then a packer plate between cylinder and block seal the bottom of the cylinder, well thats the plan.
