22mm scootopia carb mugello 186
idc23
Main scooter: lambrettatv175 3
Is anybody using a scootopia 22mm carb on mugello 186, might think about changing the 26phbh as probs with panel fouling air filter hose, just interested to see how they perform.
Thanks
Ian
Tractorman
The scootopia carbs are fine but I used a PHBL25 with a standard airbox and filter with no problems with air hose catching the panel.
You may recall that my pal "Wellerchap" visited all 92 football league grounds, did Lands End to Johhny Groats and 50,000 more miles on his early Muggy 186 with a 22mm Jetex through the air box and 42mm clubman. 56mph all day long and 65 flat out, so I imagine that the Scootopia 22mm will perform equally as well.
