Martin20 wrote:Please don't keep us in suspense for too long as I have been suffering the same on my LIS 150! I have stripped and cleaned carb more times than I care to remember, with no success. Changed pilot jet from a 45 to a 48, on Monday, played about with mixture screw, and adjusted throttle position, and at the moment, it seems to be OK, but I am not 100%confident!
sorry martin I've been having trouble finding a image host thats working to post a picture.
Photobucket have committed Hari kari and dumped on all their loyal customers .
Ok the answer is its an air leak on the inlet somewhere ....excess air at idle .
Throttle response at all other throttle positions is perfect and unaffected so it has to be due to the idle components ie air, pilot jet and slide .
I removed the hose and filter in preparation for removing and stripping the carb for cleaning and inspection and immediately saw this huge split/tear in the back of the rubber hose.
So with the normal settings there is way too much air available in proportion to the fuel at idle so the mixture went very lean and cut out . At all other throttle positions the mixture was also too lean but ironically that actually makes the engine perform slightly better ......right up to the point it seizes up
Apologies for the double post but not my fault.
Not sure what is happening but aspects of scooterotica posting are not working properly.
frequent blank screens on submitting posts and double posts etc.
