series 2 forks
li mick
after looking again it seems as though they are LI forks but there is a weld around the tube just underneath the thread on the top although the weld is very good it may mean that there has been a piece cut out at some time to lower the forks.
thanks for your help.
li mick
just out of curiosity Paul,what is the difference in the sreies 2 switchgear between the tv and li ?
thanks,Mick.
DigDug
li mick wrote:just had another look,they have holes for the rubbers.so not gp.
i'm going out to have another look again :)
I'd check inside the forks - it's easy to drill holes to fit the bolt in buffers.
Did you have to do that?
HxPaul
li mick wrote:just out of curiosity Paul,what is the difference in the sreies 2 switchgear between the tv and li ?
thanks,Mick.
The TV has an ignition switch and the swichgear is similar to a SX or GP.https://www.flickr.com/photos/ger_oconnell/4733655588/
li mick
thanks all
    Users browsing this forum: Google [Bot] and 9 guests
