Many thanks
Anyone use Mikuni TMX power jet?
alanscottj
- registered user
- Main scooter: Lambretta GP SS250 Casa
- Contact:
Got a power jet to fit to Mikuni TMX 35 - wondering what people think of them? Got dyno booked in a couple of weeks and I'm wondering if it's worth fitting it before. What's peoples experience of them?
Many thanks
Many thanks
Lambretta Series 2 Rat - RB260, SuperTourer, Cyclone 5 gearbox ππ
- soulsurfer
- registered user
- Contact:
If it's the adjustable type, just fit it!
- soulsurfer
- registered user
- Contact:
If it's the adjustable pj, then yes, fit it.
alanscottj
- registered user
- Contact:
It's not the Cam Lam one that you can adjust by twisting the top - it's adjustable in that you can change the small jets inside the main body.soulsurfer wrote:If it's the adjustable pj, then yes, fit it.
- soulsurfer
- registered user
- Contact:
In that case, I would get the CamLam one fitted, it's well worth is, more so on a Mikuni in my opinion
alanscottj
- registered user
- Contact:
What's wrong with the Mikuni one?soulsurfer wrote:In that case, I would get the CamLam one fitted, it's well worth is, more so on a Mikuni in my opinion
- soulsurfer
- registered user
- Contact:
Never used one, but the adjustable ones will work well and can be adjusted to suit changes in air density/weather conditions.
alanscottj
- registered user
- Contact:
Fitted it this afternoon - used the 80 jet - will leave main jet as it is until I get dyno done in a couple of weekssoulsurfer wrote:Never used one, but the adjustable ones will work well and can be adjusted to suit changes in air density/weather conditions.
B-Race Tuning
- registered user
- Main scooter: Lambro, GP.
- Contact:
I can't imagine even an obsessive owner changing power jet jets to suit atmospherics, and if those of you that do, do you do your pilot etc etc?
I've used the Mikuni power jets on many different scoots with very, very good results. I would say that they take a bit of setting up, especially adjusting them to the correct length you require, where you find that you get the best integration V the main. Once set-up though, a good bit of kit and no need to adjust again, even for atmospherics. I have had no need or requests to try/ fit/ set-up the Camlam one, so can't offer my thoughts on it, sorry. Now fitted to yours, be prepared to muck about a bit on the dyno, but worth it. (Before attending the dyno, see if you can make up a few spacers to "lift" it to various heights to try the differences, you'll be surprised). Simon.
- soulsurfer
- registered user
- Contact:
There are definitely advantages to some to have it adjustable, plus you wouldn't be adjusting lengths etc., so it's a lot easier to set up, but each to there own.
