AF Long Range Tank Test
Apparently AF send instructions on how to leak test their tank prior to fitting, does anyone have a copy they could share on here?
Thanks
a.lo.v2
Main scooter: sx 200
strange they don,t do this prior to supplying them.
Timbo
Fill up with water and look for leaks..... :roll: ........ :D
a.lo.v2 wrote:strange they don,t do this prior to supplying them.
Indeed :?
Timbo wrote:Fill up with water and look for leaks..... :roll: ........ :D
Im not sure thats a good idea... I read it somewhere, but I didn't read why :roll:
fluff34567
Best way is to put the cap on and block the breather. Use a schraeder valve and plug into the tap connection. Give it some pumps until pressure is felt then hold underwater.
YAMLAM
so, if you buy one , test it and it leaks ,do they refund your return costs ? or joe bloggs labour hours for making it fit for purpose ??
win or lose have a booze
davet
AF refund return postage costs???. I sent a faulty piston back and asked them to put 4 piston circlips in the replacement box. The scumbags still charged me a fiver to send it back to me.
fluff34567
davet wrote:AF refund return postage costs???. I sent a faulty piston back and asked them to put 4 piston circlips in the replacement box. The scumbags still charged me a fiver to send it back to me.
Had similar with another dealer that totally cocked up an order , incorrect parts and missing parts etc . I want to order an additional gear selector trunnion thingy as they would send another.packet anyway, they wanted charge £8 for post!
    Users browsing this forum: Google [Bot], Semrush [Bot] and 13 guests
