Running a monza 225 phbh 30 and a tsr evo exhaust, pulls clean but the cht seems high to me (between 130-145'C). I'm running 50 slide 55 idle av266 atomiser x2 needle (second clip down) and a 142 main. Does this sound about right. Tried different atomisers and clip positions and they're all too rich so this setup seems to work. Is it worth upping the main to bring the temperature down
Sent from my iPad using Tapatalk
Monza 225 phbh 30 and tsr evo exhaust
Bensmith225
- Main scooter: Lambretta gp monza 225
Have you tried a 40 slide. I ran a TS 230 (yeh i know that aint a monza) on the x13 av266 with no issues temp wise. Hope this helps.
Bensmith225
Yeah I have, I could never get it to run right with a 40 slide
- soulsurfer
Depends on what throttle position it's getting hot, have you considered an adjustable power jet?Bensmith225 wrote:Running a monza 225 phbh 30 and a tsr evo exhaust, pulls clean but the cht seems high to me (between 130-145'C). I'm running 50 slide 55 idle av266 atomiser x2 needle (second clip down) and a 142 main. Does this sound about right. Tried different atomisers and clip positions and they're all too rich so this setup seems to work. Is it worth upping the main to bring the temperature down
Bensmith225
It's between half and full throttle, I don't like running power jets
