Best stator
dazblakey
My cdi fail last night so going to order a ducati one, someone has told me that the stator will die shortly after is this true and which one will be the best to get, oh and will the timing need redoing cheers daz
Sent from my D6603 using Tapatalk
Scooterdude
Sent from my iPad using Tapatalk
Daggs
dazblakey wrote:My cdi fail last night so going to order a ducati one, someone has told me that the stator will die shortly after is this true Why would it? and which one will be the best to get, oh and will the timing need redoing cheers daz If changing only the CDI, no
garry inglis
Hi daz just because the cdi failed doesn't mean the stator will fail each is an independent part of the electric circuits you can do an easy test with a multimeter to check the stator without taking it out if you change one part at a time this also helps
cgt75b
Main scooter: lambretta
Scooterdude wrote:Image
+1
dazblakey
Cheers everyone much appreciated
fluff34567
Couldn't get an answer from him after initial contact so gave up after several attempts and went for a BGM instead.
Scooterdude
That's a shame as his stuff has a great reputation unlike BGM stators, mine failed in only a few months can't remember how much but it wasn't cheap.
fluff34567
If it fails i send it back for a replacement.. but correct not that cheap.
Norrie Bodge
Anthony on holiday ATM
    Users browsing this forum: No registered users and 32 guests
