Streatched Chain
YAMLAM
Hi,
A friend of mine adjusted his kick start ramp the day before the Hayling Rally,whilst the casing was off he checked the tension of the chain,which was fine (about 6mm of lift). On return from the rally,there was a noise inside the casing ,so quick strip down revealed the chain had streatched that much it was running on the bottom of the casing (no bottom chain guide used,MB top tensioner used). His gearing is sx200,using 48 crown wheel and 15 front. Mileage covered There and back total 168 miles.
I was thinking sprockets out of alignment but would it streatched that far in such a short distance ?
Any thoughts ?
win or lose have a booze
Morgan
Main scooter: T5 Vespa Mk1
what make of chain ?
Norrie Bodge
Check the 48 crownwheel
If it's a cheap Indian made one ?
My bet is it's not running true & oval
gaz_powell
Indian Rolooooooooooooooooooooooooooooooooooon chains do stretch
YAMLAM
Just messaged mate,who might post a few pictures up (if he can work out how) ,and gsz_powell you are correct ,it's a Rolon, I will get the sprocket checked as well.
Adam_Winstone
I've had issues with Rolon chains, which once replaced by something half decent gave no further issue.
garry inglis
Iwis every time maybe £40 but as it's a main component it's Werth it
gaz_powell
Definitely IWIS chains - no noticeable stretch on my TS motors.
Fitted a mec recently but not enough miles yet to strip and check.
I've got plenty of rolon than I've remove from SIL motors
Minority
Main scooter: Li230 S3
"Stretch" is a bit of a misnomer, that's wear that you're seeing. My experience of Rolon is that they do wear ("stretch") badly (and shed rollers sometimes). I use Japanese Tsubaki chains which work well in my motors.
Adam_Winstone
^... "and shed rollers sometimes", mine too. IMO these should be a 'get me home' spare and possible Sunday rideout chain.
    Users browsing this forum: Google [Bot], Semrush [Bot] and 32 guests
