Quality big end bearing?
vegansydney
I'm looking for a quality 22x29x14.85 big end bearing.
I normally use the Pro-X/IKO 18 roller flat cage bearings, but the crank in question (AF Rayspeed 58/107) has an odd size bearing that I've never seen before.
Any recommendations? Trying to get through to AFR as we speak :roll:
holty
Main scooter: lambretta gp
i seem to think i heard that af use a suzuki rg250 big end bearing maybe ?
vegansydney
Thanks!
I don't know the history of this crank, it could be an older one, but the bearing, I believe, is from a Kawasaki F6/F7/KD175/KE175.
I welcome any recommendations for bearing options that may be better than OEM (13034-042).
vegansydney
Ideally I'd like something similar to the 18 roller flat cage Pro-X (22.222816F) or IKO (KT222816), but fit a AF Rayspeed crank with a 22mm pin and 29mm rod ID but with a 14.8mm width.
Thanks!
    Users browsing this forum: Majestic-12 [Bot], Semrush [Bot] and 11 guests
