P Range Headset Wiring?
Lamaddict
I'm getting no power to the headlight and horn etc. Tnakfully, I''ve found another live on the ignition which was useful, so I've got one beam hooked up to that but which wire could I splice the new supply from to feed the other areas that need it?
ducksta
Check you have the correct switches for the loom, and check at regulator end that it's all correct.
mick1
Main scooter: Li Avanti 225
is it battery or none battery ? European spec' or USA ?
Lamaddict
mick1 wrote:is it battery or none battery ? European spec' or USA ?
Battery model. US spec but it's not a sealed beam. If I could just know the main wire colour going to everything normally I could just splice it onto the supply I've found on the ignition.
railfancwb
Here is a coded schematic I found. Hope it helps.
ducksta
behind the horncasting the grey on the right hand side that loops 2 connections is the main power feed ive spliced this before for live feed
    Users browsing this forum: No registered users and 30 guests
