Anodised oil filler plug - anyone used them?
alanscottj
- registered user
- Main scooter: Lambretta GP SS250 Casa
- Contact:
I have two anodised oil plugs, one red and one black, both of them leak like mad. Have tried new seals under them and just trying them with no seal just the little metal washer that they come with, but no difference, oil dripping down my casing. Put the old original type plug in and no leak whatsoever. Anyone else had this?
Knowledge
- Dealer
- Main scooter: GP
- Contact:
That sounds very disappointing, because there does seem to be a need for a replacement.
A mate had the original style magnetic oil plug fall apart, which jammed and broke his gear box, which twisted his crank and wrecked his TS1 barrel. Hard to believe that it could do so much damage.
I think there is more than one type of admonished plug on the market. Do you recall where yours came from?
Martin
Tractorman
- registered user
- Main scooter: Lambretta li150 special
- Contact:
Try using Dowty washers they are aluminium with a rubber seal incorporated.
- ForemanBob
- registered user
- Main scooter: GP RT230
- Contact:
built a good few engines recently where people asked for these... No issues what so ever... used the JPP ones
alanscottj
- registered user
- Contact:
Thanks for suggestions - will try with a rubber seal. Weird how two leak on mine - both from different places too - one JPP and other from Chiggy. Might take the breather filter out of each and check they are both clear.
Scooterdude
- registered user
- Main scooter: Lambretta LI 125 S3
- Contact:
Just blow through them, that'll soon tell you if they are clear.alanscottj wrote:Thanks for suggestions - will try with a rubber seal. Weird how two leak on mine - both from different places too - one JPP and other from Chiggy. Might take the breather filter out of each and check they are both clear.
