Autolube carb
What do you need to do to an autolube carb to use it on a non autolube engine
Thanks
gaz_powell
Just change the slide pully, the cable arrangement is different and check jetting equivalent autoube uses slightly smaller main
ducksta
I always Fill the oil track on the bottom.
