Gear Oil
Eibar-Jet200
Main scooter: Serveta Jet 200
Evening all,
Quick question and recommendation.
What gear oil do you use in your engine? Always used ST 90 but getting quite hard to locate without ordering online as no scooter shops up near me.
Can you use Castrol SAE 80 MTX?
Thanks for your input.
John
joespeed
where are you situated? can you please add your location as it is in your interest for help you may require!
i use rock oil st 90 in stock scooters ,in the quicker stuff that has motor cycle clutches i use rock oil light gear oil,all easily to get hold of from your local motor cycle dealers and best scooter shops!
Scooterdude
I've used Silkolene motorcycle gear oil light but since I've swapped over to st90 clutch feels better/smoother. I've just bought a five litre can on eBay for £16 plus post.
bazza3004
Use motul 10/30 transoil in my TS1 with cassette clutch but recently changed the standard 4 plate in mates Li and had to use the same oil in this as its all i had available and he needed the scoot. He says it works fine with this oil in and so far hasnt had any drag or slip issues.
Straight classic sae 30 same a the vespa about £3 @ liter if bought in 5lts can
Eibar-Jet200
Thank you all.
I will get some oil tracked down and let you all know.
Regards
John
Go Full Throttle in Kilmarnock or Glasgow Lambretta, would also have thought Eclipse at Tranenet might be worth a shot.
Failing that the 5 litre bottle from Lubtech is decent value if you use the board discount code.
    Users browsing this forum: Google [Bot] and 26 guests
